Brief Description: Elevator trim wiring installation...
Today I routed the remaining wiring for the elevator trim macservo to the aft fuselage. I also clamped the nav and strobe light wires into the same wire bundle going to the aft fuselage. Then I connected the elevator trim wiring at the forward end to the control stick grip wiring harness and the EFIS harness. To finish off for the day I wired the flap position sensor.
Elevator trim, nav and strobe light wiring routed to the aft fuselage
